Zum Hauptinhalt wechseln
Das Moto X der zweiten Generation (vermarktet als moto X) ist ein von Motorola Mobility entwickeltes Android-Smartphone. Es wurde am 5. September 2014 veröffentlicht und ist der Nachfolger des ursprünglichen, 2013 erschienenen Moto X. Modellnummern: XT1097, XT1096, XT1095 und XT 1093.
Why does my phone keep on restarting then shutting down again? Help!
For the past two days, my phone has been restarting itself to the Motorola logo, then turning itself off, over and over again. I've tried to externally factory reset it and clear the cache partition. Nothing has worked and it always goes back to the Motorola logo only to restart again. Does anybody have any ideas to fix this?
Note: The night before I put my phone to charge at 3%, but it was charging for the entire night. The next day it was in the condition it is now. Don't know if that helps.
Please help!
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
The micro-USB port needs to be replaced.
von Teilen
Einen Kommentar hinzufügen
3 Antworten
Download the stock firmware and flash it via fastboot.
Get into fastboot mode by holding power+volDown until you see the fastboot screen.
Here is a more detailed rundown of how to flash the images.
https://motorola-global-portal.custhelp....
War diese Antwort hilfreich?
Bewertung 0
I would check your charger. What you describe sounds like an extremely flat battery. Plug in a different charger that you know works and see what happens. Otherwise you may have a problem with the charging board or circuit
Bewertung 0
Probably, the micro-USB port needs to be replaced. UbreakitIfixit, a national chain could fix it.
Bewertung 0
Antwort hinzufügen
Eric Amaro wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 810
