Screen only shows gray and black lines?
My Tab only displays black and gray vertical lines, but I can hear that the unit is powered on, what might be the problem? Is it repairable? Thank you!
Ist dies eine gute Frage?
Looks like the LCD for this went bad or became loose from the board itself. It is definitively repairable, but I do recommend that you purchase the LCD and Digitizer assembly if you are going to do this yourself.
War diese Antwort hilfreich?
I had the same problem replaced the screen and digitizer and still it's black with gray lines
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 747
