Zum Hauptinhalt wechseln
Asus X450JN BSOD after upgrading
Greetings,
I have just recently upgrade my Asus X450JN with these items :
2x8 RAM Corsair Vengeance DDR3L
SSD Samsung 850 Evo 250GB
I replace Optical Drive with original 1TB Toshiba HDD + HDD Caddy
Few days after, BSOD appear in my laptop, It won't even boot to installation media
Any insight on why it happened and hpw to fix it ?
Thanks and Regards
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
http://www.asus.com/US/support/FAQ/10039...
ASUS Haswell platform Notebook shipped with low voltage memory DDR3L(1.35V). If user want to upgrade the memory , please also choose low voltage memory DDR3L(1.35V). It will cause no boot when the notebook which shipped with low voltage memory DDR3L(1.35V) exchange the memory to standard voltage memory DDR3(1.5V).
The link above will show you how identify the difference.
This could be the problem causing BSOD
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I have confirmed that I used DDR3L, I suspect more on the SSD
Interesting update is that everything went normal after I try to check the drives using GParted booted from USB, it happened twice already since then and booting GParted somehow solves it, I just booted and then turn it off again, no changes are done
von
similar case..but didn't work after using GParted..need better solution..why only single slot memory were active not 2 slot?
von
hi my frend, I have the same pc, i´m looking to do the same. our laptop can take 16g ram ? will be very good, I boucht the same ssd and caddy cover.
the original slot of memory it´s 4g+4g ? or one of 8g ?
Bewertung 0
Antwort hinzufügen
Heggi Ramatya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 776
