Zum Hauptinhalt wechseln
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
replace lower intake manifold
how do i remove lower intake manifold
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
What engine do you have?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
First remove the upper air chamber then remove the fuel rails and injectors make sure you have drained the engine coolant completely before unbolting the intake then once the coolant is out remove the bolts that secure the intake and pry from a corner to break the seal of the old gasket. If you go to youtube you can usually find all sorts of videos on this. As Im not sure on the engine or year I cant show a specific video
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
For some reason I have a that goes right through the lower intake manifold, how do I remove the valve to take off manifold?
von
@mr_dawsey it would be good to have your exact engine and year, it seems that there should be videos on YouTube according to the previous posts, good luck.
von
Antwort hinzufügen
fernandorudolfo189 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 48
Insgesamt: 2,181
