Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Short circuit in iPhone charger
Hello,
The sequence of events: Came home with a dead phone, see two new chargers on the table (brother got from Aliexpress),and quickly putit to charge. I left phone to charge. After aprox. 2 hours of charging I took phone in hands and see that it charged to 100% and in the mean time I pressed home button and something happened in the wall socket where it was plugged in. It sparked and smoked a bit, so I quickly put the cord out.
It looked like everything is normal, but since then my phone is not charging, because it always shows '' This ACCESSIORIES may not be supported '.
That charger was unfortunately fake, but even if I use my original it shows the same.
Now it can be charged only when it is switched off and battery empty very quickly.
But it is recognized in itunes normally.
I changed the battery, restored it, clean up dock connector, tried restart it, etc. etc.
The phone is no longer under warranty.
Does anyone have any idea what could I do?
Thank you to everyone who could help me,
Andraz
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I will try and report how things will go. Thanks for help
von
Hey everyone, i'm new here. So, i want to know the next. Today i was about to charge my iPhone, and when i plugged in my apple charger into the electric current, and it made a short circuit! it lighten from inside and started to smell like burned wires and won't work, the phone was connected and is not waking up
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
I guess you could try replacing the dock connector and try using a quality phone wall charger and lightning cable.
War diese Antwort hilfreich?
Bewertung 1
If replacing the dockConnector doesn't help, it is likely a problem with the charging circuit on the logicboard. You will need a real professional to replace therevalent chips.
Bewertung 1
How to check i phone 6 charging port shorting
Bewertung 0
Marta dump-truck in the flesh
Bewertung 0
Antwort hinzufügen
Andraz Reich Pogladic wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 11,472
