Zum Hauptinhalt wechseln
2.3L 4cyl or 3.0L V6, 6th Generation
Why is my engine smoking and shaking
I pulled out to turn from a red light and I kind of gave it some gas and the check engine light came on. Then, the car just started shaking, so I pulled over to a close gas station and sat a while with the car off. Then I tried to start, but it wouldn't, so I tried again, and it started but only stayed on for a few seconds and started smoking and turned back off. Last week, I went to turn it on and it shook very hard and started smoking again, and I just went to the car to try to turn it on and the car is dead.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Most likely is a major failure such as a thrown rod. From your question I can see that you're not a mechanic. Have it towed in for a major overhaul and be prepared to spend some serious money to get it fixed.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
+ agreed. Could be timing chain, head gasket, rod, crankshaft, or any number of other things. Take it to a mechanic.
von
Excellent answer +
von
suggest to buy CARMD can order online its very helpful will tell u whats wrong with ur car if anything wrong with it and it will tell what to fix and alot cheaper to repair too .. just a suggest ..
Bewertung 0
Antwort hinzufügen
prettyboytmty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 6,464
