Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
after replacing battery, will not charge,turns on only when connected
After replacing the battery the phone only comes on when connected to wall charger. Battery % at 48% does not change and lightning bolt is on.As soon as taken off the wall charger the phone turns off. Will not charge with usb cable on computer.Can not make or receive calls,no sound.Did Try holding the power and home button until apple logo but no change.Does this sound like the dock connecter/charging port needs to be replaced or could I have done something else wrong when replacing battery?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It sounds like the battery connector to me. Here is a good video about a similar problem. I'm not sure about the battery percentage though.
War diese Antwort hilfreich?
Bewertung 1
There is a chance you could have damaged a charging IC when disconnecting the old battery. Its also possible that a charging IC was bad, which led you to believe your battery was bad. I'd bet money on one of the charging IC's being at fault.
Bewertung 0
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 92
