Replacing turn signal/wiper/cruise control combination switch
I have the replacement parts, but need some information in replacing the old one.
Ist dies eine gute Frage?
Vom Mercedes Typ W123 gab es verschiedene Modelle wie 240D, 300D, 300TD, 280E und mehr. Es handelt sich um Limousinen, Coupés und Kombifahrzeuge aus den Jahren 1977 bis 1985.
Rep: 1
Simply pull off the rubber cover, using a flat screw driver to help if needed. You will then see a bolt that holds the assembly in place, and a few screws that hold on wires. Remove those, and then unplug the wire harness plug. With all that done you should be able to pull out the old switch. Installing the new switch is just the reverse of this.
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 577
