Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
Help identifying the CORRECT Logic Board Part #
MacBook Pro 13" Retina Display Late 2013 -...
Howdy folks! A customer of mine has a MacBook Pro who's logic board that was damaged by water. A water bottle spilled in her laptop bag . The red water indicator under the trackpad ribbon connector is positive for water damage. I am looking to properly identify this board so I can order a new one. I thought the BEST thing to do is share a picture of her back cover so you smarties can see for yourselves what model and other machine specific identifiers.
I'd also like to ask if you know where to get parts from a REPUTABLE distributor.
THANKS in advance!
Glen
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here is your part.
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
Replace a broken or damaged 2.6 GHz logic board in your Mid 2014 MacBook Pro 13" with this part. Bild
Produkt
$149.99
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
I used http://www.everymac.com to ID the computer via serial number.
von
Apple Part #: 820-3476-A
@ilabbe - once you do identify a machine, it's best to correct the icon so they can get to the guides
Here's the replacement guide: MacBook Pro 13" Retina Display Mitte 2014 Logic Board austauschen
von
Correct the icon? I'm not sure what your mean. But THANK YOU GUYS for your help!!!
von
Ahhhhhhhhhhh!!!!!!! <Screaming like a frightened 5 year old girl> $700 dollars??????? My customer will fall over backwards, BUT... now that I know the part number I suppose I can look elsewhere.
Thanks again!
Glen
von
You might want to finish your profile so you can establish yourself as a professional with iFixit to get better pricing. Click on either my icon or Johnathans to look at those profiles.
Bewertung 3
2 Kommentare:
Thank you Mayer!
von
Yes, that price is way out of line and not at all in line with current prices on the marketplace. I would contact customer support and ask for a price update after you are set up as a reseller. But as you may know, other part sellers sometimes put an artificially low price on a part and then when you go to buy it find it is out of stock. Here's an example : http://www.powerbookmedic.com/MacBook-Pr...
von
Antwort hinzufügen
Glen Comstock wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 39
Insgesamt: 1,712
