Zum Hauptinhalt wechseln
Die sechste Generation des von Google designten Android Smartphone, welches LG produziert. Modell LG-H790. Veröffentlicht im Oktober 2015.
Bricked Phone help me bring it back Alive
please guys anyone help me !
what can i do to my phone i was facing some problems with it and my friend tried and failed by loading a wrong boot on it so the phone is worthless right now it's not starting or giving any respond when i connect it to my laptop and i didn't get the chance to use it i only used it for a month .
Please any suggestions or ideas would be appreciated
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
i'm using a converter because in my country we don't have the proper cable
von
Hi, how is everyone doing? I also bricked my device. It's also not able to go into fastboot. It's a moto G X1032, and android 5.1 was installed on it before flashing. I tried using file from this link https://forum.xda-developers.com/moto-g/... to revive it but it failed. please help, thanks.
von
Einen Kommentar hinzufügen
2 Antworten
You likely just need to reflash the factory images. Just boot into fastboot by holding volume down and power, and flash the factory image from here: https://developers.google.com/android/ne...
If your phone shows QHSUSB_BULK in device manager, it is much more complicated. It seems that there is no unbrick method for the 5X currently if you are stuck in that mode.
War diese Antwort hilfreich?
Bewertung 0
10 Kommentare:
i pressed volume down and the power button put it didn't do anything
von
Plug the phone into the computer, what do you see in device manager?
von
it says unknown USB Device
von
Can we get a screenshot? Also what cable are you using.
von
von
5 weitere Kommentare anzeigen
So, what was the final chapter? Could you turn it on? I have this issue: sending sparse 'system' (524289 KB)... FAILED (too many links)
Bewertung 0
1 Kommentar:
try a different usb port
von
Antwort hinzufügen
Mostafa Heikal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 5,924
