Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Fehlerdiagnose und zum Auseinanderbau des Apple iPad der zweiten Generation mit GSM-3G-Mobilfunknetz (AT&T), erhältlich mit 16, 32 oder 64 GB Speicher. Mit Dual-Core-A5-Prozessor. Veröffentlicht im März 2011. Identifizierbar über die Modellnummer A1396. Reparaturen erfordern den Einsatz von Hitze und vorsichtiges Hebeln.
Backlight does not work ...
My iPad 2 has fallen down.
Since then there is no backlight (the screen seems to work fine because when I use a torch I can see everything on the screen) and also the digitizer cracked.
I have removed the cracked digitizer carefully and checked inside the iPad for further damage which could explain the backlight failure. But I couldn't find any other damage. Everything looks OK.
How can I find what causes the backlight malfunction. Is it the screen or is it something on the board?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Hello again
I cleaned the connectors from the logic board and the LCD screen, but still no backlight. Then I tried to hold the power and home button for 15 seconds and nothing happened. The iPad just turned on. What am I doing wrong with the power and home button combination?
I would also like to ask something else. Is there a schematic or something like that for the backlight circuit so that I could find the right components and test them by using a multimeter? eg voltage, resistance, continuity, etc.
von Teilen
If you search up Louis rossmans YouTube channel you may be able to find it there.
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would say try cleaning the LCD cable connectors from the logic board and the LCD screen itself and at the same time try reseating them and hold the power and home button at the same time for 15 seconds and try turning it on again.
It could either be a faulty screen or the backlight component(s) on the logic board have become broken.
No signs of any physical damage on the LCD screen correct? Well since you can still see display but without backlight I'm leaning more towards logic board component damage like I said before.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Socrates Gertsos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 412
