Zum Hauptinhalt wechseln
Die sechste Generation des von Google designten Android Smartphone, welches LG produziert. Modell LG-H790. Veröffentlicht im Oktober 2015.
89 Fragen Alle anzeigen
Looking for Nexus 5x Schematics
I have a Nexus 5x that won't charge because of water damage. I opened it up and it looks like there might be damage on the quick charge circuit but I don't know what to test for. I need some schematics to see what parts are supposed to be capacitors and what parts are filters or resistors. I have tested the battery connectors on the motherboard and I don't have any voltage there. Also the place where the quick charge chip is heats up when it's plugged in. Does any one know where I can get schematics for a Nexus 5x? I can't seem to find them anywhere on the internet.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
forum.gsmhosting.com is where I have the most success finding phone schematics in searchable pdf format, but it’s pretty hit or miss and lots of old, dead links. I can’t find the 5X on there at the moment, but I’ve found many other useful ones in the past.
War diese Antwort hilfreich?
Bewertung 0
After more research I have found that most smartphone manufactures do not release schematics for there devices. So it looks like I am out of luck for finding schematics unless they are released. I will try to troubleshoot with my multi meter more and hopefully be able to find the broken connection or component.
Bewertung 0
1 Kommentar:
Hey I know I'm a bit late on this one, but I am now going through the same issue, and I need the schematics too. Did you eventually get it? If you did, could you send it to me please?
von
Antwort hinzufügen
alexander wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 3,178
