Black screen after fall
Hi, I dropped my phone and the screen completely cracked and went black. I could hear that messages where coming but could not unlock the phone.
I have replaced the digitizer since then in the hope that this may fix the problem but with no results. I can turn the phone on but nothing else.
I have tried the soft reset but it doesn't seem to work.
Any ideas of what may be wrong? I am trying not to go for the hard reset as all I really want from the phone are my kids pictures.
Ist dies eine gute Frage?
4 Kommentare
When you mean digitizer is this just the glass + touch screen part or is it also the LCD display as well?
As it sounds like the LCD has gone bad / cracked after the drop which will also need to be replaced instead of just the digitizer.
von Ben
Hi Ben,
yes I mean just the glass as I was hoping that this was the problem. As you pointed out, it most likely is the LCD that was broken. Is it easy to replace? I think I might as well buy a new phone, but don't want to loose my kids photos.
Thanks for your help.
von Miriam
Thanks Ben for your reply. I have replaced the LCD and the phone turns on and is almost back to normal except for the bottom 3 button which won't work. Any suggestions as to how to fix this problem?
von Miriam
When replacing the LCD / Digitizer, did you pry out the charging port daughter board or did you leave it in there?
Because I think that connects (via multiple golden connection prongs) with the 3 touch sensitive buttons on the front display housing frame.
von Ben
