Zum Hauptinhalt wechseln
Modell A1418 / Ende 2012 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
212 Fragen Alle anzeigen
little spider behind my screen
hello today I noticed a little spider behind the glas of my screen :( no idea how it got there. is there a posibility to get it out. i got the imac which has the glas glood on the screen.
thanks for you help.
johannes
Update (07/18/2016)
EMC 2544
21.5" imac late 2012
hope you can see the sider on the pictures
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
I don't think you picked the right model. Please look on the bottom of your stand and give us the EMC #.
von
Can you post a picture? Also verify your model like mayer said. The screen on the newer imacs are assembled differently, as the glass is fused to the LCD with LOCA glue.
von
Actually, it's assembled with OCA for the newer models Ethan, same as most phone screens today, it isn't LOCA, would be far too messy, basically a non liquid version. :-)
von
Anyway, as both Mayer and Ethan have said, please give us the EMC number, if you have had it repaired recently by a third party, I would take it back.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Thanks for the EMC #, it is a Late 2012 and the display is one piece. I have changed the icon to the correct one. It is sealed, (or supposed to be). I don't have definitive answer for you. You could try removing the screen, and using compressed air from the opposite edge of the display and see if it can be blown out or at least moved to where it's less obvious. What concerns me, is where its mother and is your machine full of these?
Here's how to remove the display, but you will need an adhesive kit to put it back together.
iMac Intel 21.5" EMC 2544 Display austauschen
[verlinktes Produkt fehlt oder ist deaktiviert: IF173-005]
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
I have no idea where the mother is :D the machine is still working fine no idea how it got in there. i can try to do that.
thanks for your help.
von
Before you open it up I would bring it into an Apple Store as clearly during the manufacturing process it got in. I would hope they would replace the screen under warranty. If they won't then give Mayer's idea a try.
von
I agree with Dan. See if Apple will replace it first. If not, that adhesive kit also has the cutter in it to go to the correct depth in removing the display.
von
Hey johanneskoepf22,
Can't you just suck it up with a vacuum cleaner?
Bewertung 1
2 Kommentare:
Try to place the vacuum cleaner at the bottom of your iMac
von
ok i will try that thanks.
von
Hello, I have the same problem..
A spider is behind my screen, I have Imac Late 2015 27', how can i solve this problem?
Bewertung 0
I have the same issue, the spider was alive a few days ago and eventually dead in the middle of the screen. Very annoying. Anyone have any luck with getting apple to remove spider from their screen? There isn’t any spider in our office and per all the picture I saw with the same issue, it seems to be the same type of spider?!? Maybe the egg got in during manufacturing process?
Bewertung 0
Antwort hinzufügen
johanneskoepf22 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,530
