Zum Hauptinhalt wechseln
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
20 Fragen Alle anzeigen
Why has the camera locked up?
Camera is frozen. Screen is on (special effects/image mode) & lens extended. Camera will not turn off or respond to menu, playback or directional keys. What do I do to un-freeze /unlock it?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Didn't see any answers, so I simply opened the battery/SD compartment and removed SD chip then battery. Put them right back in and everything is working again as it was before it locked up.
War diese Antwort hilfreich?
Bewertung 7
11 Kommentare:
I ended up trying this and it actually worked, thank you!
von
yes, it worked! Thank you for sharing your idea.
von
Thank you, that worked!
von
Thanks a mill...it really worked
von
This worked untill I try to zoom in and then it freezes again
von
6 weitere Kommentare anzeigen
The best solution is using a SD Memory Card with great data transfer rate, like Sandisk Extreme Pro 95MB/s.
After change SD Memory, the camera has not been frozen or made this issue! Hope it help.
Bewertung 1
1 Kommentar:
My memory card is a SanDisk Extreme 64 GB with "45 MB/s" on the label. Is this really too slow for photographing my dogs in the Scene Sport mode of my Nikon CoolPIX P950? It may be time for a faster card.
von
Antwort hinzufügen
Sarah Moles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 73
Insgesamt: 10,572
