broken female 3.5mm jack?
Just curious if there is a way to replace/fix the 3.5mm headset jack in the xbox one controller.
Female part of the 3.5mm jack is broken! Basically with a headset plugged in directly to the 3.5mm jack if I move the headset post/plug the audio cuts out for about 15 seconds.. the audio sounds lackluster & has some white noise as well.
Any info helps, thanks!
Ist dies eine gute Frage?
3 Kommentare
Still looking for help.
I disassembled the controller & the small 3.5mm jack & housing is just a peice that literally sits in between the top & bottom circuit boards, it is not secured or soldered just has small circular contact points on the lower circuit board.... I took it out & nothing apeared to be damaged...
Btw..
I use a hyperx cloud 2 headset that works perfectly on any device other than the xbox one controller. I only play bf4 & forza 6.. the worst static & audio clipping is on forza 6, it produces way less/ almost no static on bf4.
I will also add that I cannot find a replacement 3.5mm jack. No one sells them & no one knows where to get one. You can find every single part for the controller, but the only part you cannot find is the 3.5mm jack
von SUBRWHO
Try Amazon.com
von Stephen Dick
I just ordered a Repair kit with three 3.5 jacks included,you can buy just the jacks about $10,00 for I think 5.
von Stephen Dick
