Zum Hauptinhalt wechseln
Das iPad Air 2 ist der noch schlankere Nachfolger des iPad Air. Es wurde am 16. Oktober 2014 angekündigt.
450 Fragen Alle anzeigen
Why do I have no sound on my iPad?
I have no sound on my iPad, the sound works with headphones. Please help
Update (07/25/2016)
Well it hasn't been broke or anything (although once i dropped it on some grass). It wasn't wet grass (I think)
It an iPad Air 2 running iOS 9
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Kurt, could you give us some more details? The model if the iPad would really help. Also, has the iPad been repaired recently? Any drops or water damage?
It could be as simple as a cable came unplugged or a bad speaker or it could be more complicated. A little more information from you will really help out.
von
Unfortunately I do not have any information as the forgotten iPad is now lost and bricked.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The iPad Air 2 & original iPad Air share the same basic design. So you'll need to review the iPad Air's IFIXIT guides.
Most likely the headphone socket is damaged. Within it is a switch which disconnects the internal speakers. Unlike the MacBook's & iMac's which the sockets can sometimes be fix without opening, I have found the iPad's really need to be replaced. Here is the IFIXIT guide you'll need to follow: iPad Air Wi-Fi Headphone Jack Replacement and here is the part: iPad Air 2 Headphone Jack Assembly . If you have never opened a iPad it's not easy! And you can damage the display in the process if you don't have the correct tools.
I would recommend you bring it into an Apple Store or an Apple authorized services center.
iPad Air 2 Wi-Fi Headphone Jack Assembly Bild
Produkt
$6.99
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
Uhh, no. There is no problem with headphone jack, its the speaker.
von
But thanks anyway
von
No, its the jack! It directs the output to the speaker (Vs the headphones) via the switch which is broken.
von
oh
well thanks now i know
von
I had the same problem. I tried everything with no luck. Recently I removed an old app I wasn't ever using and voila my sound came back.
von
Antwort hinzufügen
KURT C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 5,170
