Headphone jack not working even after replacing it
Headphone jack on my iPhone wasn't working so I ordered the new cable and replaced it and all was well except it had the same exact problem, could my luck be so bad as to have to pieces broken in the same way or is there something else going on?
Ist dies eine gute Frage?
6 Kommentare
Try cleaning the connector pins for the lightning dock ribbon connector with a brush and 99% isopropyl alcohol with the battery unplugged. Then plug back in and test again.
Is it stuck in headphone mode / no sound coming at all from headphones or not detecting headphones?
von Ben
It's not detecting the headphones at all, I'll try the cleaning
von Steven
@benjamen50 So I did the cleaning and it worked at first si unplugged and plugged the headphones in a few times to make sure and then it stopped working :-/
Also, how important is the isopropyl percentage?
von Steven
Higher is better as a lower percentage means it's higher conductive if I'm correct the other 1% is water / liquid instead of solvent.
von Ben
99% IPA = 99% pure = 99% alcohol and 1% water, usually distilled. And if pure enough, that water will not conduct electricity, until it gets contaminants from the phone/board you are cleaning. But by that time and if the alcohol content is high enough, most of it would have evaporated .
In my opinion anything above 90% is good enough for general cleaning purposes. 99% is better of course.
von Rany
1 weiteren Kommentar anzeigen
