Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 does not charge after charging flex and battery replacement
I have replaced both parts (Charging flex and Battery) but the mobile cannot charge the battery. The mobile starts and works normally but the battery never charges.
Someone can help me, please??
Update (07/29/2016)
No, mate. Nothing appears when I connect the charger. I tried it with many chargers and lightning cables but nothing happens (from the wall sockets and with the computer through USB).
and yes, when I connect the charger when the mobile it is shutdown, it starts.
I have ordered another charging flex because I think the problem is that because sometimes the mobile says "Cable not supported".
Thank you for your answer, mate.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi
Does it show any thing when you connect the charger to it, i mean a charging block or lightining bolt sign.
Also does it turn on when you connect charger to it when it is turned off.
von
Sounds like you have a faulty charging port. Where did you get it from?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Change the charging flex and if it remains not charging then it's a U2 ic problem
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Sergio Fernandez Espinar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 127
