Zum Hauptinhalt wechseln
1.6, 1.8, or 2 GHz G5 processor
20 Fragen Alle anzeigen
Display power inverter pinout or voltage for each of 6 pins needed?
I have a broken LCD on my netbook. The LVDS cable correctly fits in the display for my iMac which was gutted when the logic board caps went bad.
I have tossed the logic board. I still have the display, the power supply and the inverter. I need to know the voltage that each pin on the inverter takes to power the back light on the iMac display directly from the power supply.
The following links may be helpful to someone who speaks French.
http://forum.macbidouille.com/index.php?...
[ http://users.skynet.be/fa835376/pas%20a%...]
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This is from an iMac G4 is this something that you are looking at?
The inverter has 8 pins in as described below.
Blue = 11.93v
Red = 11.93v
Blk = GND
Blu = GND
N/C
Yel = .2mv
Prpl = 3.262v
Orng= no voltage detected
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Check this out and see if it will help you.http://dremmeljunkie.blogspot.com/2010_0...
Good luck
von
Also if you have the part number here you can look up the specs
http://www.jkllamps.com/index.cfm?action...
von
Antwort hinzufügen
Shane Nelson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 6,515
