My A33 dies after few minutes outside and works perfectly inside
After just a few minutes outdoors (and always in the shade) my A33 will shut off and the power button will be red. I will then charge it (though it charges quickly indicating the battery wasn't depleted) and the same sequence occurs again. Yet indoors it performs well for hours. Of course the volume is much higher outdoors but that shouldn't affect it. I even tried a wired connection on AUX to eliminate a possible bluetooth error but it still drops out and fluctuates in volume up and down but at a very low level with the power button red. This speaker is designed for outdoors use but it doesn't act like it. Can you enlighten me to what the problem might be?
Ist dies eine gute Frage?
Have your checked the temperature of this device, it maybe overheating. Just a thought.
von Henry
burnssefton do you plug it into a power source when it is inside/outside? "it charges quickly indicating the battery wasn't depleted" not necessarily. A battery that has failed and does no longer hold a charge will do the same. If you keep it indorrs and run it at the same volume as outdoors, does it turn off as quickly?
von oldturkey03
