Head light not turn on
The head light for my Ford Expedition is not on..I change the light Bulp and still don't work
Ist dies eine gute Frage?
1. Check Fuse
2. Check Connection (Wiring)
3. Check Switch
War diese Antwort hilfreich?
There are separate fuses for each headlight and I believe they are in the interior fuse panel. It is on the right side of the instrument panel. If the fuse is fine, check the ground wire and the low and high beam wires at the connector. These steps should pin down the problem. Good luck!
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 138
