Zum Hauptinhalt wechseln
15" HP laptop with a 2.16 GHz Intel Core2 Duo Dual-Core Mobile Processor, released in 2008.
dv6700 consumes more current than stock power supply can provide
The notebook hp pavilion dv6700 p/n FF761EA#ACB doesn't start when its stock power supply is used. When another power supply (in fact powerbank) with larger maximum current and the same voltage is used, it starts and works (no longer than powerbank battery can provide, about 30 minutes). It doesn't work with another new power supply equivalent to stock. It is possible to use it with more powerful power supply, but it seems to be dangerous because more current means more power and more power means more heat, so the problem should be found and fixed.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@kolanich the original power supply has an output of DC 18.5V, 4.9A, 90W How much does your "other " power supply have? Your higher wattage could be okay, depending on by how much it is higher. My first thought here is that your power supply no longer supplies what it should. Check that one first.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you for the answer. Another power supply (the new one) with the same wattage and voltage was bought and unsuccessfully tried, so it seems that the trouble is inside the device.
von
Okay so we know that it is not the power supply. How much biogger is the power supply that works? You may be looking at a battery issue here...
von
Antwort hinzufügen
KOLANICH wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 28
Insgesamt: 416
