Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Full washing machine cycle salvage?
Co worker put IPhone 5s through full cycle with IPhone on. I've placed it in rice, should get the screwdrivers to open the phone come Tuesday and i'll take it apart and place it in rice for another few days. Placing the new battery I'm buying. Any take on if this is salvageable and if the battery doesn't work, how do I check logic board?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Rice does not do anything for your waterlogged phone except let the water sit longer which causes further oxidation. What you should do instead is take the phone apart. Disconnect the battery and remove all of the components from the logic boards. Remove the covers from the logic boards, as they hold in the water, and run them through a good ultrasonic cleaner for 20 minutes. When finished, submerge the logic boards in 99% iso alcohol for a few minutes to displace the water. Let these dry completely. That should stop the oxidation which is what will cause further damage.
As for the damage that the water is done, it may be too expensive to fix. There are a few companies that can look at the logic boards and make that determination or possibly recover your data.
Good luck and avoid the Rice
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Joe Eimert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 70
