Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
3 beeps and/or pressure applied to case causes lines or power shutoff.
Sometimes the computer will simply give me 3 beeps and not turn on. Other times it will boot up normally, but if I apply pressure to the case to the left of the trackpad or lift and move the computer around with any kind of velocity it will display lines like this and either go back to normal after releasing pressure or shut off:
I have tried every kind of RAM configuration and with different verified RAM sticks, and have determined it is not (at least simply) a RAM issue. Also, the battery is not bloated and only has 230 cycles
When the computer is booted up and left undisturbed, it functions normally.
Any wisdom you guys might share would be much appreciated!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
See if it is doing the same thing with an external monitor.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hello.
It looks like you are facing with the cold soldering issue on the legs of the memory socket.
Re-soldering the legs will solve the problem.
War diese Antwort hilfreich?
Bewertung 3
7 Kommentare:
How do you do that?
von
@mayer, I think they mean to reflow the pins of the memory socket with hot air.
von
As soon as i can, i'll upload pictures of that. All you need is a microscope, a fine soldering tip, the flux and solder.
You have to remove the tapes covering the legs to get better view.
We face with this problem at least once a month.
von
You can't reflow that, the hot air will melt the plastic.
With hand, one-by-one.
von
I will be very interested to see the photos. I've not done a repair like this and have minimal soldering experience... Thanks @chiio
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
goodcyning wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 116
