HDMI input on my 4k LG not working
LG flat screen 55uf645
My inputs
Is not working it said check I puts
Update (08/30/2016)
Yes tried all HDMI ports 4k only works on hdmi1
Ist dies eine gute Frage?
My inputs
Try removing all HDMI cables and then "remove" the power cord for about 10 minutes (powering off is not sufficient ). Then Plug in the power cord, then one HDMI cable and try your device that way.
Also, something to note there is a known flaw with these tv's that cause a spike on the motherboard that cause the HDMI ports to stop working altogether.
http://www.lg.com/us/tvs/lg-55UF6450-4k-...
Look under ratings and reviews.
Hopefully the reset will get you backup and running though.
The board replacement is not hard either though.
Hello there!
If after trying what Henry suggested to do, the HDMI inputs are still not working on your TV, then you need to replace your Main Digital Board.
If your Tv model code is 55UF6450-UA.AUSYLJR, then the part number for the main board you need to replace is EBT64048902
Good Luck!
Mike W
Rep: 1
The solution sounds crazy but remove the main board and bake it in the oven to allow the weak solder joints to reflow, it will normally last about a year or two depending on use, when they go out again, repeat.
Letzten 24 Stunden: 9
Letzten 7 Tage: 69
Letzten 30 Tage: 320
Insgesamt: 29,897
Hi,
Can you prove that the device(s) that you wish to connect to your TV using a HDMI connection are working via HDMI by connecting to another TV? Have you tried using a different HDMI cable? have you tried all the HDMI connections on your TV?
von jayeff
yes used different TV, New HDMI cable, tries ALL three HDMI ports
von Larry
can HDMI board be replaced
von Larry
