Zum Hauptinhalt wechseln
A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
Why is troy bilt spray oil from air fliter
why is troy blit spray oil from air filter
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There is a breather pipe into the air filter and because of this, you will always get some oil into the filter. What I have found to be the problem on the ones I worked on was too much oil in the engine. It is only supposed to be filled to the line on the sight glass.
Check the oil level.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
phillip wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 611
