Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
iPhone no sound, black screen, no vibration when plugged in
I dropped my iPhone and it has a black screen, doesn't make any sound, doesn't vibrate when plugged into the charger. But when i plug it into iTunes it recognizes my phone and it shows that my phone can still charge. DO you guys thin my screen and digitizer is broken or my logic board. Like when i plus it into my computer, my computer makes a sound instead of the iphone, and when i hold power and home when plugged into the comp for 10 sec, it makes another sound.
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
So i woke in the morning to found out that my iphone x that's on the charger won't turn on , i tried pressing the power button it won't turn on , i tap on the screen it won't work. then i following the force resting steps and it's didn't work and i plug it up to the computer and the iTunes doesn't show up ,what should i do now ?
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
might be stuck in recovery
try using the mute switch to see if it vibrates when switching.
if it vibrates then its a screen issue. if not then its in recovery.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
it doesn't vibrate
von
does itunes say its in recovery or does it say the entire phone info like normal? if its normal then the phone might be disabled or some how the vib is not working.
von
how can i exit on the recovery mode?
von
recovery mode will automatically restart to normal operation after period of time reboot on its own. but you can always hold power and home to do a normal restart that will start a normal boot sequence.
von
I have the same problem!
after a very very small stroke the screen turned black, no sound, no vibration. but itunes recognizes it but I can not access it because I can not put the pin and make a backup. do you think you disconnected the connector? the technician told me the faulty display. But the vibration and the sound that do not work? are all connected to the screen???!
thank you
Bewertung 0
4 Kommentare:
Hi I have iPhone 7 plus as same problem. Did you solve that problem?
Please tell me how.
Thank you so much!
von
I am wondering the same thing. I think usually if the screen is bad the vibrator and sound still work. I am very confused on mine. No drops. No water damage.
von
Hi! How did you manage to solve it? Have the same problem here too
von
Have the same problem, changed the whole motherboard and nothing, I don't know what else I can do, hopefully someone has an answer to this problem
von
Good morning, how did you solve the problem?
Bewertung 0
1 Kommentar:
Hi! Have you solved the problem? Have this too
von
I have had the same problem after replacing the battery on iPhone SE. I thought the new battery was bad, but when I plug it in iTunes starts backing up and syncing like normal and show the battery charging.
I have done a lot of iPhone repairs and I cannot figure out if I did something wrong or if I just had really bad timing.
Bewertung 0
How did you solve it? Have this problem too
Bewertung 0
1 Kommentar:
I didn’t solve it. I had to scrap the phone. Replacing the screen didn’t do anything.
von
Antwort hinzufügen
muning wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 35
Insgesamt: 3,553
