Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
MacBook not booting, gets stuck on Apple logo
My Mac ran out of battery one day and when I charged it up again and tried to boot it, it gets stuck on the apple logo.
I've tried to boot to safe mode to which my computer does not respond and I've also tried to reset the NVRAM.
I do hear the second chime but after that it goes back to the apple logo and loading bar and remains stuck.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Can you give us your exact model. Review this listing: MacBook Pro models. Once you locate it paste a URL link to it here in your question so we can see what you have.
von
Yes like Dan says, post your exact model number.
Also hold option key and power it on and keep holding the option key until you see some disks on the display. Report back what you see on the display then
von
it's a MBP 15.4/2.2/2X2GB/500-5400/GLSY.
It should be this one: http://www.everymac.com/systems/apple/ma...
Holding any key did not result in any movement of the computer. I brought it to an affiliate of apple (I'm in Mexico, no apple owned mac stores here) and diagnosis showed that it was the graphics card that was defective. According to them, a known problem by apple for this model.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To be doubly sure:
  • Do you have a bootable Thunderbolt, FireWire or USB drive you can plug in? If not you could create one from another system. Can you boot up from the external drive?
  • Or, you could boot your system in Target Mode connected to another Mac via Thunderbolt or FireWire cable. Once connected can you access the HD on your system?
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
Here's the repair program on the video issue: https://www.apple.com/support/macbookpro...
von
either of those options require me to have access to another mac which at this point I do not. Let me try to get my hand on one and revert. Thanks!
von
Thank you @mayer for the feedback. One the basis of this program they have applied to apple for the replacement of the material.
von
Your machine is known to have the problem but it has to be connected to Apple to prove it and run the test for Apple to qualify you for the logic board replacement program. Was the place you took it to an ASP?
von
meanwhile, back up the hard drive in case hey mess with it.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Carla wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,074
