Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Can I replace my MacBook Pro mid 2012's HDD to a SSD
Is it possible to replace my 13" MacBook Pro Mid 2012 model's Hard Disk Drive to a Solid State Drive?
I need faster speeds and was hoping that Solid State Drives are able to be a replacement for my slow Hard Disk Drive.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Your systems specs: MacBookPro9,1
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, your system can support a 2.5" SSD replacing your current HD. Make sure you get a large enough drive. You'll want to leave no less than 1/3 of the drive free if you have anything smaller than 512 GB SSD anything larger you'll need 1/4 free. Unlike a HD, SSD's need more free space.
Here is the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement
But before you physically replace the drive you'll want to prep your new SSD drive. You'll want to get a SATA to USB adapter like this one: Startech 2.5" SATA to USB adapter.
To prep your new SSD drive connect it via the adapter using Disk Utility from your system format the drive with a GUID partition map and Mac OS Extended (Journaled) petition. Download the OS installer to your system and run it if you don't already have it. At the end the installer will ask you if you want to migrate your user, apps & data to your new drive. Select as you need the user data and migrate your stuff over.
Once the system restarts you're ready to swap your drives. One word of caution here. This systems SATA drive cable is fragile so do be gentle. If you encounter any issues I would recommend replacing the cable as the first thing. Here's the IFIXIT guide to do that: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement.
MacBook Pro 13" Unibody Mid 2012 Festplatte Bild
Anleitung
MacBook Pro (13 Zoll, Mitte 2012, Unibody) Festplatte ersetzen
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
MacBook Pro 13" Unibody Mid 2012 Festplattenkabel Bild
Anleitung
MacBook Pro (13 Zoll, Mitte 2012, Unibody) Festplattenkabel austauschen
Schwierigkeitsgrad:
Leicht
10 - 25 minutes
War diese Antwort hilfreich?
Bewertung 6
2 Kommentare:
Hi there, I've just done all the above, and now am running my mid 2012 MacBook Pro (A1278) via USB on my new Samsung SSD. My concern is if I swap them out now (i.e. put my SSD in where my old HDD was), will it all start up OK? Will the system automatically calibrate to a new SSD on its SATA connection?
von
To simplify things I always put the new drive in and then use the old drive via the SATA to USB adapter. In either case you'll still need to use the Boot Manager to select the drive to boot from (with both connected).
Reference: Mac startup key combinations
In your case you have an additional step as now you also need to set the Startup Disk setting in Prefs to the SSD. Once set you're good.
von
Do these steps still apply if the current format of the Mac HDD is Journaled & Encrypted? Do I need to set up the new SSD as the same format? I keep running into error messages
Bewertung 0
Antwort hinzufügen
ag3ntan0nym0us wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 40,008
