Zum Hauptinhalt wechseln
Erschienen im Oktober 2014; Android-Betriebssystem v4.4.4, bis zu v5.1; 32/64 GB Speicher und exklusiv bei Verizon Wireless.
Why Won't it come on after repair?
Three weeks ago, my phone randomly stopped working. It was minding it's on business sitting in a corner and all of a sudden the screen stayed black. I could hear the notifications but it wouldn't turn on(the screen). Then I charged it and when I would try to power it on, it made the power up sound and vibration but didn't light up. No lights would light up. I was told it was my LCD so I ordered a new part, replaced it and made sure the ribbon cable was secured and I still got the same result. Now if I try to turn it on, the power up sound keeps replaying every 10 seconds til it dies, or i disconnect the battery, still without and sign of life in the new screen/LCD or even notification lights. What could be the problem?
NOTE: It was in some heat that day, but it's always hot here. The screen had a crack and some small glass chips that had fallen out from the top left corner from a previous drop months ago, but other than that it was perfectly fine.
Thanks so much for any advice!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
That happened to me and I figured out if u just leave it for a couple of days then put it in charge and it should automatically have the charging sign then the apple logo and it should turn on
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks @alberty Should I leave it on the charger all day for a couple days? I left it on last night
von
No cause I tried that and it didn't work so I left alone and I tried turning it on everyday
von
And also it happened more than once so I think it might be that the phones been used for a long time so that it's like out of use
von
It’s possible the display connector isn’t properly seated. I’ve had that happen or just a blinking LED notification light would come on. After reopening the phone and disconnect then reconnect the cables everything worked fine. It’s also possible the new replacement display is defective.
By the way, if I turn on an Android phone and the Apple logo shows up, I’m droppin’ off the grid.
Bewertung 0
Antwort hinzufügen
mesha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 862
