Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
After changing the housing it shows that is charging but it isnt.
Hello.
Today I have changed the housing of my Iphone6, because the old one was very damaged. Everything went well till I have tried to charge it after it died.
Now it shows me that is charging when i connect it, but it doesn't charge.
Any idea of what might happen ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Check if you didn't knocked any chips on the motherboard.
Also check if you didn't damage the charging flex, since it can be easily teared due to the hard adhesive.
War diese Antwort hilfreich?
Bewertung 1
The first thing you should have done was change the battery but as you says its damaged then it was good to replace but if its not charging after you put the new charging port then change the battery and that will sort your problem and if it dosnt you will have to go back and check that the charging port that you put in has gone in the exackly the way the old one came out down to the screws. Ok goodluck.?
Bewertung 1
Antwort hinzufügen
Gabriel Serban wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 65
