Why wont my printer go past print head loose or missing
how do i remove the print head on my Kodak ESP C310
Ist dies eine gute Frage?
Printers use logic circuits, which are computer circuits that operate by recieving inputs and sending outputs. The logic circuit is picking up an input from the print head that it is interpreting that the print head is bad. The logic circuit that is directly connected to the printhead could also be causing the error code
War diese Antwort hilfreich?
So what you need to do is replace the carrier mechanism/printhead, if the error remains replace the logic board that the printhead is directly connected to.
Bullseye is to be mashed when installing print head. There is a gray latch above bullseye you press to release print head.
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 14
Insgesamt: 2,681
I have tried to press hard on the bullseye fingernail little stamp but I cannot get the printhead out of its position. I have a Kodak ESP 3250 machine and its not letting the colour cartridge seat into the open box for it. I have tried with Kodak to get the instructions but they are just saying I have the wrong cartridge but its a Kodak 10C. How do I remove the printhead as Ive said I tried the pressing hard on the label with the fingernail on the target but nothing happened. HELP!
von Jean Sampson
If I could transport my Kodak ESP 3250 printer scanner to somewhere within a reasonable distance from Milton Keynes or Bedford I would do so to get the printhead exchanged because I think its the printhead that has had its day.
von Jean Sampson
Please reply to me message and give me details of approx cost of replacing the printhead if that is the reason for the printer not working.
von Jean Sampson
Is this the board on the back of the print head?
von Craig Moris
