Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Screen stays black but receiving calls and buttons work.
The phone vibrates and even rings. I can use Quicktime (record) to see that the phone is actually working. The screen stays black on the device though and since it's locked I can't use Siri. I tried a soft reset and it doesn't work.
Which parts would I need to replace?
I'm worried cause I hadn't backed up the phone in a month and that's a lot of videos and recordings of live performances that will be lost if I can't do anything. I don't think there is but any way to backup the phone if it's locked and iTunes asks for passcode?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi,
Any recent drops? Any liquid damage? Any recent repairs? If you could answer them we could help out much more.
Either way, you could try a new screen and see if that solves your issue, if not, the backlight has probably blown on it and would require microsoldering.
If it is liquid damage, the corrosion would need cleaning up and then the logic board would need to be evaluated to see what has been damaged and what needs replacing etc. :-)
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks for the quick answer. It was dropped yesterday. Had a cheap cover and it worked normally all night and stopped working this morning.
von
I would take it to the Apple Store as it would still be under warranty! :-)
von
Will do. Thank you!
von
I had this exact same problem plug it in and leave it for like 5-10 min it got my screen back on on my 6
Bewertung 0
1 Kommentar:
Sadly, this didn't work on mine. Thanks though
von
If its black all the time then shine a torch in to see if you can see anything if you can its the backlight fuse its only £35 to repair
Bewertung 0
I didnt drop it of drop any liquid on it ,i just woke up to a black screen
Bewertung 0
Antwort hinzufügen
Rafael Torres wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,315
