Zum Hauptinhalt wechseln
Released 2016, January, identified by model number K430T. The type of display is IPS LCD capacitive touchscreen, 16M colors and a 13-megapixel camera.
40 Fragen Alle anzeigen
Power button failing when in the dark?
Just got a LG K10, for some reason if I'm in a dark area the power button/volume buttons become unresponsive. This issue does not exist in well lit environments. Anyone else experiencing this, or does anyone know why this might happen?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I started having this issue ever since I got my screen replaced. I think it's some kind of hardware issue. If I'm in the dark and this happens it's because I have the brightness all the way up. When the brightness is on 0% and I'm in the dark I don't have this issue. So try lowering your brightness. Glad I'm not the only one with this issue
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Performed a factory reset last night, this did not resolve this issue. I will say though I did a little more trouble shooting and I might have figured it out.
I recently put a protective case on the phone that has a tempered glass screen protector. It could be that the tempered glass is somehow triggering the proximity sensor, making the phone think it's next to someone's head. Then with that sensor tripped and little to no light detected the phone thinks it's best to not turn of the screen.
War diese Antwort hilfreich?
Bewertung 2
The light sensors may trigger your device .
So the best solution for you before you do anything else,is to factory reset your phone
Bewertung 0
1 Kommentar:
So ,you have figured it out .Great ,happy for you :D
von
I have the same issue.. Im reading up on this... has to do with the tempered glass everybody recommends remove the tempered glass find a tempered glass with cut out for the sensor by the camera
Bewertung 0
This is bs my screen just blackens when the proximity cencor is covered where do i trun this shot of?
Bewertung 0
When in the dark area my phone swicth fail to come
Bewertung 0
Antwort hinzufügen
Gage wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 13
Insgesamt: 2,596
