Zum Hauptinhalt wechseln
The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
HP g62 347NR no display on screen
I have a HP G62 347NR that powers on but there is no display on screen
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Connect an external monitor to the laptop and see if there is a display showing on it when you turn on the laptop.
If there is no display showing on the external monitor you most probably have a GPU or motherboard problem.
If there is a display showing on the external monitor, try holding a torch at an angle close the the laptop screen and see if you can detect the Windows desktop being displayed.
If you can see the Windows desktop this way then you most probably have a backlighting problem.
If you cannot see the Windows desktop this way then you either have a faulty video cable between the motherboard and the screen, a faulty video cable connection on the motherboard or the LCD screen or a faulty LCD screen.
War diese Antwort hilfreich?
Bewertung 6
Antwort hinzufügen
SINCLAIR ROBERTS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 1,734
