Zum Hauptinhalt wechseln
The Canon PowerShot A470 is a 7.1 megapixel digital point-and-shoot, announced January 2008.
15 Fragen Alle anzeigen
Camera no longer connects to my computer to import photos
Camera is not longer recognized by my computer (iPhoto). New pictures on camera are not showing up in iPhoto.
Also camera requests that I reset the date & time every time I turn on the camera.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
First regarding the date and time. You need to replace the date and time battery in the camera. Here are some images on how to do it.
Regarding your camera download problem, have you tried a different known working USB cable or a different USB port in your computer? Have you upgraded either the computer OS or the iPhoto software recently?
If you have upgraded the OS for your computer, have you got the latest drivers for the camera installed in your computer? Here is a link, select the appropriate OS for your computer, http://search-au.canon.com.au/canon__au_....
Downloading and installing the Camera DC software should install the latest drivers available
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
The new battery corrected the date/time issue. Thanks so very much!
Regarding the other issue, I downloaded the updated software with no success. Also changed USB ports with no success. iPhoto doesn't even recognize that the camera is plugged in. Do you have any other suggestions? Is it time to get a new camera??
von
Hi, Visually inspect the USB port in the camera with a magnifying glass and a good light to see if all the pins are still there and are straight and parallel with each other and that there is no dust or lint clogging the port.
If it looks OK try plugging the camera into a different PC (make sure to turn the camera on). With Windows it should identify that there is a new device connected. I do not know anything about how Mac's behave. If nothing happens then the USB controller in the camera or the USB port in the camera is faulty. You did try a different USB cable didn't you? You didn't mentioned it.
von
Some cameras need to have a "USB Mode" turned on for them to be seen by the computer. With your settings getting reset maybe that did to. Alternatively you could just take the SD card out of the camera and plug it in directly if your Mac has a SD card reader, the newer iMac's and 13" MacBook Air and all MacBook Pro's have it. Or you could buy a SD card to USB adapter like this: https://amzn.com/B00IX9ZDKC
Bewertung 1
3 Kommentare:
It is just so odd that as of yesterday the camera connected to iPhoto and today it does not. Frustrating. I just ordered a new cord . . . hopefully that is the solution. Thanks again!
von
I just found the SD card slot on my computer (who knew?) and it worked PERFECTLY!!!!! Thank you soooooo much for all of your help and patience! ;)
von
No problem, glad it worked.
von
Antwort hinzufügen
dpakler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 2,199
