Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Hi, Could you clarify your question please? Have you dropped the phone and now can no longer make calls or do calls drop out while you are talking? Please provide more detail as to your problem. The better the description the more helpful the answers.
Hi, If calls are dropping out, what are the signal strength bars showing? Does it happen on outgoing call, incoming calls or both? Does it occur if using the phone with the charger connected and switched on?
The more details about what is happening the more appropriate the answers will be.
This question was migrated from http://meta.ifixit.com/Answers.
von iRobot
von jayeff
von jayeff
