Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
Cheesecake stuck in headphone jack
Alright so... me being the stupid teenager i am, I dropped my iphone in my cheesecake. It's stuck in the headphone jack and my volume doesn't work, it's also in the microphone and speaker. I don't have enough money to replace the phone or the components, please give me a cheap hack to fix my phone! My mom will kill me if she finds out what happened :(
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Best option at this stage is to turn the phone off and use the sim pin that came with it (or something equally small, like an earring) and clean out as much as possible. Make sure the headphone port and the lightning port are as clean as possible. If you have fine tweezers, a small amount of cotton wool on the end of them could also help. If the above is unsuccessful you will need to have the headphone jack ribbon cable replaced.
War diese Antwort hilfreich?
Bewertung 2
On a dry day, place it next to a bed of sugar ants. They will fairly quickly have it cleaned out.
Bewertung 2
1 Kommentar:
Can you please help me with my Macbook Pro "mayer" ? Thanks (link to my question: Reseated RAM, blank screen, beeping every 5 secs. tried everything ...)
von
Try using a vacuum cleaner to suck out the bits of cheesecake from the headphone jack. Also use it to attempt to clean the speaker and mic. Use tweezers and a pin carefully to do the rest.
Otherwise, my only other thoughts are to clean it of cheesecake as much as possible and dare I say it, return it under warranty.
Regards,
Barney
Bewertung 1
Antwort hinzufügen
Fall Out Narwhal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 173
