Zum Hauptinhalt wechseln
Die Xbox Spielkonsole der dritten Generation von Microsoft kam am 22. November 2013 auf den Markt;
727 Fragen Alle anzeigen
Replacement fan for power supply
Hi
I need to replace the fan inside the power supply. I cant find any for sale on the net. Does anyone hav a prtnumber or link for that part
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Rune, I had previously posted the wrong replacement fan, apparently OEM power supply fan hard to find, a lot of links say fan not available, plenty of complete power supplies though if you had too go that way. Check the link below, Kenny tells how he installed a replacement fan 10x10 fan from Mouser BFB0512HHA-C with good results. Hope this helps.
https://www.reddit.com/r/xboxone/comment...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you
I have red the article
Grease only works for a short time. I will try the other solution in the article, buy a Mouser BFB0512HHA-C.
Your answer was very helpful, thanks again for finding this link.
von
If you check my xb1 power brick disassembly guide I have a photo of mine which clearly shows the fan info. Just search xbox one power brick disassembly on ifixit. I hope this helps you find what you
Update (08/24/2019)
Replacement found $10+ shipping. This was just a very quick search and only checked 2 posts on amazon. Maybe possible to find it cheaper elsewhere so you'll have to do some online browsing. Happy gaming!
https://www.amazon.com/AB5512HX-G00-DC12...
Bewertung 1
Antwort hinzufügen
Rune Skarbom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 36
Insgesamt: 10,884
