Why my ipad mini4 no sound?
how can i fix my ipad mini sounds?
Ist dies eine gute Frage?
Make sure the device isn't muted. Check the rocker switch on the side and also press volume up. If that doesn't work, go into settings > sound and make sure everything is set right there.
Report back if you still have issues.
War diese Antwort hilfreich?
still no sounds
has it been dropped or had any water damage?
Still no sound. I'm typing this with my volume up and I can't hear the sound.
Still no sound..is it broke down
iPad mini 4 doesn't have a rocker switch.
You can go to settings>General >reset>reset all settings. That should fix the no sound problem.
piece of headphone is stuck in the port
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 18,836
