Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Fragen Alle anzeigen
HDMI output not working
Is there any fix for the hdmi output as this has stopped working, I've had to resort to using the RCA connections/start adapter which has reduced the quality of the picture. Any help will be greatly appreciated.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Have you checked the input device and cable?
von
Cable works fine as use it on Wii-U, tv is fine too
von
Einen Kommentar hinzufügen
1 Antwort
You can try resetting the system software, but other than that, the only solution would be to replace the motherboard.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ian Clarke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 94
