Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Really loose power cord
Hi everyone
Recently, my PS4's power cable has been falling out for no reason, even with the normal vibrations of the console. I'm pretty sure it used to be a snug fit but now even if I just touch it it falls out. Do you think it's just a faulty cable, or could the actual power port inside the console have moved? I tried slowly pushing the cable in but it won't go past a certain point and never fits securely.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
Thanks, I've ordered a replacement cable so I'll give it a go :)
von
OK...hoepfully that fixes it. Be sure to post back here to let me know if it does.
von
Yeah, it was the cord, the new one fits securely. Thanks!
von
Great! Glad that fixed it!
von
I’m having the same problem rate now it wouldn’t turn on right if it’s a loose fit right plz say yes
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
There's no way to know for sure without seeing it in person. You may be able to shine a flashlight in where the power plug goes and see if anything looks amiss. You also may want to just go buy a new power cable first. It's a lot cheaper and hopefully that would fix your problem. If that didn't fix it then you may need a new power supply (or yours could possibly be repaired).
Hope this helps.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I've had a PS4 since launch and have always had the same issue with an incredibly loose power cable, which would just casually drop out if I slightly move my ps4. I've only just realised you really need to push the cable in with some force and it will fit much more snug and will not just drop out. Bad cable design imo, most cables don't require that amount of force to connect properly so I didn't think this would.
von
What happens when i pull it up and it wont come on and i had it fix
von
My power cable is the same and I'm getting my room done at the moment so I'm worried of moving it in case it doesn't turn back on
Bewertung 0
1 Kommentar:
Well i sent mines to be fix and now it my cord to it ugh
von
I had. Sent my ps4 to be fix and. Now its the power cord in the back of the ps4 this is crazy what to do someone need to tell me something
Bewertung 0
Antwort hinzufügen
pandarock32 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 104
Insgesamt: 20,151
