Zum Hauptinhalt wechseln
T800 Battery decreasing while turned off and on charge?
Hi
I have a Samsung T800 tablet and which is having some serious trouble charging. It originally had a damaged charging port which was replaced and since then whenever its plugged in to charge the battery keeps draining even while switched off. This also happens with a new battery.
Any ideas?
Thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
@hortman did it ever work properly after you repalced the charging port? Have you verified that the replacement is properly installed?
von
It did work here for me when i changed it. port does seem to work properly, it shows the battery symbol when plugged in and has the little bubbles. Should I try another?
von
So from what you are saying that it is indicating that it is charging but it is not? I would double check the connector and the connection.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@hortman if your connector and the connections are properly installed, follow the troubleshooting suggested by Samsung.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks oldturkey03 thats exactly what I need, sorry its taken so long to reply, been busy with other repairs
von
Antwort hinzufügen
Hortman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 96
