Nook shuts off when SD is inserted
NOOK model BNRV200. I just replaced the battery, nook turns on but when I insert the SD card it shuts down and will not power back on. I can only get it to turn back on when the SD card is removed. All functions work when SD is not inserted.
Ist dies eine gute Frage?
Check the SD slot to make sure no contacts are crossed or there is nothing jammed in there that would short out the contacts when SD is inserted. Also make sure that this SD card is of the correct size for this tablet and has been formatted correctly. It may need reformatting or replacing. Also check the work you did on the replacing of the battery. Make sure nothing is bent shorting out or broken.
von DR Paquette
