Zum Hauptinhalt wechseln
Model A1311 / Ende 2009 / 3.06 oder 3.33 GHz Core 2 Duo Prozessor
310 Fragen Alle anzeigen
How to replace mini Displayport of an iMac 21.5" with a 27"?
I know that you cannot connect any external source to the iMac 21.5" to use its display. But the 27" mini displayport offers input so that you can connect, for example, your PS3 to it and use it as a display. My question is this:
How do you replace your mini displayport on an iMac 21.5" with the mini displayport of an iMac 27" and would it accept input?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It's not related to the port itself rather than to the graphics card. The 27" iMac features an special card that accepts input from a mini displayport, something similar to a video capture device. Which, in turn, may be a solution for you.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
+ good answer, could you provide a supporting link for this?
von
Apple T/N on DisplayPort & Target Display Mode: Apple Mini DisplayPort adapters: Frequently asked questions (FAQ) & Use your iMac as a display with Target Display Mode
And here more on Target Display Mode: The Ins and Outs of Your iMac’s Target Display Mode and lastly the loss of it in the newer iMac's: iMac Target Display Mode No More
von
Antwort hinzufügen
cenkz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 3,322
