Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
6 Kommentare
I had this issue as well. It's not the latch, or the control board, or anything else I saw on here. For me is was a simple fix. Remove 3 hex head screws from the back that hold down the top panel of washer. Slide toward back and lift off of machine. In the front, opposite the latch, inside, there are 2 "quick connect " wire inserts. The top one is for the latch sending signal to control board so the start button knows the latch is engaged and will now work. Mine was not clipped in all the way and shook loose because of heavy spin cycles I presume. Just push it in till it clicks. Easy as that in my case. *Obviously disconect from power at the wall outlet 1st. This is literally a 5-10 minute fix/ check. With no out of pocket cost. If it's not your issue then it was only a few minutes of your time. Good Luck.
von Troy Cirillo
Oh my god man, totally worked for me! Thank you!!!
von Rippletone
Thank you, this totally works!
von lisa patterson
I believe I have same issue. My fix may not be as easy because I have stacked my dryer on top of my washer. I just want to confirm that there is no way to get to this fix without removing top panel, which will mean taking down my dryer.
von Roxsen Koch
My model 110 washer won't lock. Just get 3 beeps. Latch problem?
von Soni Barney
1 weiteren Kommentar anzeigen
