Looking for WiFi Antenna Part?
I note that iPad 2 Bluetooth/Wi-Fi Antenna says its not for the EMC 2560 model, but is there a suitable antenna available somewhere?
Ist dies eine gute Frage?
I think this is it: http://www.powerbookmedic.com/Wireless-3...
War diese Antwort hilfreich?
Sorry but that one says its the 3G antenna not the Wi-Fi one ?
I've replaced hundreds of iPad 2 antennas and never worried about which model it was. The connection is the same on them all and the mounting is the same. There are no electronics to deal with, its all analog.
You should be good to go. I do remember seeing a couple iPad 2.5s with weird antennas. If you could post a pic of yours, I could tell you 100%
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 124
1 Kommentar
So what's the verdict, does this one work? The post labeled as the answer is indeed AN answer but hardly a solution and leaves the issue annoyingly unresolved and in an ambiguous way. I indeed have an iPad EMC 2560 that I'm about to replace the logic board in and was going to grab the cheap & especially fragile parts for the numerous reasons to do so and not that I won't be able to complete my repair without it but now I'm just curious what is so different or incompatible about the EMC 2560's and what's the solution or reccomendation if one should happen to require a replacement antenna for this model. Thanks in advance.
von Nick Novia
