Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für eine Vielzahl von Matratzen.
making the foam mattress pad fit the queen size mattress
I currently have a regular queen sized mattress but its firm but it was new and free. it is also uncomfortable, so I purchased one of those foam mattress toppers to put on top of the mattress. Now I sleep better but the problem is even though the topper is supposed to be queen sized ...it slips and slides and doesn't meet all four corners of my existing mattress. Which mean every morning I must pull or tug it back to the other side. How or what can I do to prevent this from happening?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Get yourself a set of sheet straps, $5:
https://www.bedbathandbeyond.com/store/p...
War diese Antwort hilfreich?
Bewertung 1
cassandra, Bare mattress material pretty slippery, try putting a fitted cotton sheet on the bare mattress, then the mattress topper, then another fitted sheet, holds pretty good. Other methods are carpet tape(2 sided tape), sheet garter(corner-elastics at the dollar store), anti slip mats for under carpet or as drawer liners also found dollar store,hardware stores,etc. cut a couple into wide strips and place between pad and mattress at corners and middle perimeter.
Bewertung 1
@decodiva67 really not much you can do about it. If it is really bothersome I'd go with some wide industrial strength Velcro between the topper and the mattress.
Bewertung 0
Choosing a new mattress is a difficult task. There are hundreds of facts that you have to consider when buying a mattress. Few of them are firmness level of the mattress, comfort, back support and body contour, no pressure creation on your body, motion separation, edge support, sinking & sagging, etc. If you consider these facts you may get a good comfortable mattress. You can learn more about mattress problems reading these articles below.
https://www.mattressinsight.com/soft-mat...
https://www.youtube.com/watch?v=nDZrmt8B...
https://www.mattressinsight.com/new-matt...
https://www.quora.com/Firm-mattresses-gi...
https://www.mattressinsight.com/mattress...
https://www.mattressinsight.com/can-bad-...
Bewertung 0
Antwort hinzufügen
cassandra baker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 40
Insgesamt: 12,069
