Zum Hauptinhalt wechseln
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
Will not drain or spin makes a buzzing sound
How do I fix this problem if I bypassed the lid switch and it still does nothing what is the problem
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Dwayne Ramon what is the proper model number of your wahser and where do you hear the buzzing? It will not spin if it does not drain. Problem could be your pump, your filter. kinked hoses and other things like the lid switch.
von
Kenmore 800
Buzzes but don't drain or wash lower buzzing
von
@Ron Haas
What is the model number of the washer?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Dwayne, Kenmore 400 washer will not drain or spin makes a buzzing sound.
Possibly the water pump is seized/clogged/plugged, remove water pump and check pump for debri and remove blockage. Good luck
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Dwayne Ramon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 8,841
